I've got a re-occurring problem that seems to be getting worse. What started as only happening a few times is now happening almost every time I drive the car and happening quicker into the drive. I can get the car into gear with the stick shift fine every time but it wont come out of gear when I push the clutch in. Its happened in 1st, 2nd and 3rd so far. To get it out of gear I turn the car off, can pull the stick shift out of that gear it was stuck in and start the car and drive again.
Any thoughts on what I should try/look into first? Do I have any issue with the clutch system or a transmission?
I appreciate the help, thank you in adavance.
Stick shift wont come out of gear - Zeke2100:47:08 02/19/22
